Thread: Booked in to Vauxhall
    Blantyre
    Default Booked in to Vauxhall
    Well... dunno if its me or not but i think the revs are holding up slightly whan changing gear, so while i was out yesterday i booked it in to vauxhall aldershot
    I also think there is a slight rumble as you change into 3rd........ Mrs cant feel it ...... must be a man thing
    So there gonna check and advise if there is any issue with the clutch & DMF
    DMF will be done under warranty she assured me, if the investigation proves that its at fault...... what do you think the cluch will cost me .... car has done 39k
    Regular Member Robbie69's Avatar
    Sounds like the clutch, my old a3 did it just b4 I had to change the clutch and flywheel, it will just get worse until it goes, hope you get it sorted.
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    Revs are supposed to hold for a bit on petrols are n`t they , for smooth gear change .Does it on my dads 1.8 vvt , he also thought there was a problem
    Blantyre
    Quote Originally Posted by Penfold View Post
    Neighbor said that also, and maybe as its a SRI 2.2d
    We'll see thanks for the info
    Apr 2008
    manchester
    hi folks
    mine also did that if anything they rose 200/300 rpm,took it back and they updated software so they said that was about 5 months ago.Must admit does'nt seem as bad now
    did make a post at the time as it was very very noticable.
    57 plate 2.2 sri
  1. well its booked in
    By nidgeboy in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2011, 21:49
  2. Booked the Vec into MIJ
    By tommychimp in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 18:44
  3. Booked In
    Last Post: 1st November 2010, 15:24
  4. Booked car into Vauxhall
    By vectra-probs in forum Engine & Drivetrain
    Last Post: 4th February 2010, 15:16
  5. Booked car into Vauxhall
    Last Post: 4th February 2010, 15:01
