Thread: Full Load, Deep Grind sound when braking?
    May 2008
    London
    Default Full Load, Deep Grind sound when braking?
    Got a 2.2 Dti 2002 90K,
    On new years day driving my family around, about 70Kg x 5 people.
    I noticed some deep grinding sound at the front of the car when coming to a stop or doing a bit of heavy breaking.
    Driving on my own, it still happens but its very faint unless i brake quite hard.
    Having checked the brake pads, they seem fine, but looking at the paperwork, it seems that only the rear brake discs and pads have been replaced.
    What do you think it could be? I was thinking of changing the front brake discs and pads? as I dont have any other squeeking, grinding or knocking sounds going over humps etc.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    sounds like your pads are shot to me m8
    May 2008
    London
    Thanks mate, I'll double check them 2moro.
    Regular Member mohojo's Avatar
    Canberra, Australia
    I reckon that it could be your front disc rotors, particularly given that your pads seem fine.
    The car I had previous to my Vectra (a Holden Commodore) would do this after frequent heavy braking and with more occupants in the vehicle. Replacing the front disc rotors cured the problem. I think it was something to do with the rotors getting thin and not dissipating the heat as well as they used to.
    Northants
    Hi, i had this problem for a while coming from the front passenger side. spoke to loads of people about this and no one could give me a straight answer. My pads had loads of life left in them as did the disks, eventually replaced both pads and disks in between xmas and new year, done almost 1000 miles since and havent heard it at all. ( touch wood) !
    Regular Member Signumv6man's Avatar
    Suffolk
    Trim : Elite Auto
    Engine : 2.8 V6 Turbo
    Quote Originally Posted by kktdragon View Post
    90k is a lot on original disks !!!, would expect 50 - 60k max, suggest changing pads and disks for good practice anyway at that mileage, reckon it will almost certainly cure your problem. You don't say if you're DIY mechanic or not but doing the work yourself will save a packet!!!!!
  1. Knocking sound when braking
    By JezzerD in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2011, 20:44
  2. Vibrating sound when braking.
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd March 2011, 22:15
  3. Deep droning noise under moderate/heavy braking...
    By Westy SRI in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2010, 13:33
  4. strange grind noise
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2007, 16:55
  5. Grind/Scrape @ 2000rpm
    By Basil in forum Engine & Drivetrain
    Last Post: 10th November 2005, 14:22
