Results 1 to 2 of 2
Thread: Mk5 Astra calipers same as Vectra 302s?
    Belfast
    Default Mk5 Astra calipers same as Vectra 302s?
    My Mk5 Astra had 308mm front brakes on it - the calipers say 302mm on them though.
    What's the chances the calipers are the same?
    Really want to up the anchors on the SRi from the Corsa-class ones it has at the moment. 302mm would be ideal if I only needed discs and pads.
    I guess I'm hoping I can bosh the old Astra calipers on in place of the 285mm calipers using the same brackery, and then add new pads and discs. I doubt that I'd be that lucky though.
    I can get pics tomorrow if needed - I don't fancy venturing into the "shed" this evening in the dark.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Cant help on calipers, but the disks are different part numbers. The Astra ones are 25mm and the Vec C ones are 28mm.
  1. Are Vectra & Signum calipers the same?
    By Gayno in forum Suspension, Wheels & Brakes
    Last Post: 12th March 2011, 20:07
  2. Replacing Vectra VXR Calipers
    By staccato in forum Handling & Braking
    Last Post: 3rd January 2010, 20:45
  3. astra vxr discs and calipers
    By fixerman in forum Handling & Braking
    Last Post: 28th December 2007, 15:27
