Thread: My AFL Is Pi**sed
    Regular Member Hynzy's Avatar
    Liverpool
    Default My AFL Is Pi**sed
    Got in the car tonight, and started driving along, and the warning light came on. Got out the car to check it, and the drivers side xenon is pointing inwards.
    When i start the car is does the normal sequence, up down left right but the drivers side only goes up and down.
    Its gotten itself stuck pointing inward.
    Has this happened to anyone at all, any solutions?
    Guess what aswell.... Ive got one day left on the Network Q. What are the chances of that happening.
    Better than no days left on it dude....
    Oct 2007
    estonia
    Had one the same case.
    take the lamp off car. if you remove the xenon lamp rear cap you see the left-right moving motor and a steel cable from the motor to the lamp mechanism. the cable position can be adjusted. losen the screws of the cable, move the lamp in center position and tighten screws. put back to car and test if the lamp moves as should.
    maybe it helps
    Regular Member ccsnet's Avatar
    The local dealers if driving my old Vectra
    Quote Originally Posted by chrischrischris View Post
    Love the title ( have visions of a cross eyed veccy ).... did you get it sorted ?
    Terran
