Results 1 to 9 of 9
Thread: High Revs and Low Acceleration on 1.8 Vectra
    Jan 2009
    Norfolk
    Default High Revs and Low Acceleration on 1.8 Vectra
    Hi Guys. My Veccy has been getting gradually worse over the festive period to the point its not safe to drive imo. Basically over the last few weeks the revs have been shooting up randomly as I am driving. I cant even use the cruise control as even with my feet on the floor the revs shoot up and cut the cruise control off! Its now got so bad theres hardly any acceleration because the revs just go mad when I press the pedal and my speed barely changes and sometimes I feel like im driving in glue! Any ideas whats wrong? I have a 52 1.8LS Vectra and only got 51k on the clock.
    Appreciate any help
    Mileage : 000
    I wonder if the Air control valve could do with a clean, it might be "gummed"up and is sticking.
    haworth
    could it be the clutch slipping? does it tend to happen when you are accelerating or going uphill the engine revs higher,
    Jan 2009
    Norfolk
    It always happens when I accelerate wherever I am but its got so bad now that the speedo barely moves even when the revs shoot up to 4500!
    Mileage : 000
    I did think of the clutch too. But he did say that the rev,s shoot up randomly. So I presumed he meant they increased without any driver intervention. If you do think it might be the clutch try starting off with the handbreak still applied the revs will go up but the car should not move too far, if the clutch is on ot,s way out. If you can feel that the car is trying to move forward then the clutch is probably ok.
    Jan 2009
    Norfolk
    The revs increase without me doing anything when the cruise control is on therefore cutting it out when it happens. Otherwise it shoots up anytime i try and accelerate. If it is the clutch that needs replacing how much would I be looking at and is it worth doing if the car is worth a couple of grand tops? Thanks for your help so far really appreciate it
    mansfield notts
    hi, i have a similar problem on my 03 sri, i thought the clutch was slipping, but found this not to be, put handbrake on and let off the clutch expecting the engine to rev, but it eventually stalled after dragging the rear a foot or so, so now i think it is the throttle position sensor thats u/s, untill it gets really bad, i will live with it, don't want to get fleeced by the local bandit armed with his tech 2
    Regular Member poves's Avatar
    Dec 2007
    lancashire
    Manual / auto ?
    Aug 2006
    EVERYWHERE
    Revs shooting up with no difference in forward motion with a manual box is usually (if not always) down to the clutch slipping.
    Try it on a slight gradient at about 30mph in top gear,press the gas pedal and if the revs rise but there's little or no difference in the cars speed then it's deffo the clutch.
  1. high revs
    By andy_richmond in forum Engine & Drivetrain
    Last Post: 12th October 2012, 18:43
  2. jerky acceleration on VXR (Z28net) low revs
    By nipmads in forum Vectra C / Signum Troubleshooting
    Last Post: 14th August 2012, 12:59
  3. Vectra Sri 1.9 150 No power until high revs
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 12th May 2012, 17:35
  4. Strange noise under acceleration 1.5-2.5k revs?
    By Thom in forum Engine & Drivetrain
    Last Post: 20th September 2011, 14:52
  5. No/poor Acceleration under 2.5k revs
    By Diesel Dan in forum Engine & Drivetrain
    Last Post: 16th December 2010, 23:44
https:www.vectra-c.comforumshowthread.php65863-High-Revs-and-Low-Acceleration-on-1-8-Vectra
revs increase when chahging gear vectra c 2008vectra c revs up when drivingvauxhall vectra over revving2006 vectra revving on own no powervauxhall vectra suddenly revs high on acceleration 2.2 elite06 vauxhall vectra 1.8 sri how to improve accelerationmy vectra auto revvingwhy do my revs go up and down on its own in a vectra c 1.8vauxhall astra no power acceleratingopel signum reving on its ownvectra 1.8 no power when acceleratingvauxhall vectra club 1.8 petrol 04 reg sometimes jerky in 2nd gear once i give it gas its okayvauxhall astra estate 02 high rev no powerhigh revving on vauxhall vectracar over revs when acceleratingvauxhall astra club 1.8 automatic highrevs no powervectra c 1.8 high revs no speedrevs high on t reg vectravauxhall vectra sri 1.8 no power when acceleratingopel vectra 2016 1.8 revs vs speedvectra 1.8 petrol clutch high revvauxhall vectra high revsVetra c no power on accelerationcorsa c revs high but no increase in speed
