Thread: brake problem
    cumbernauld scotland
    Angry brake problem
    hi
    i have a 54 plate vectra 2.0 dti was driving it this evening and all 4 wheels have locked can anyone please help. thanks
    brake pads are sticking on to discs
    Nicking Ya Dinner.
    Have you changed them recently? if you have did you use the wind back tool on the rear ones?
    As for all 4 corners locking on, this would seem an ABS issue to me, best get some pro help with it tbh.
    Mileage : 000
    As said above. If all four wheels have locked up and are not releasing there is a problem with the ABS unit. Can the car be driven or are the wheels totaly locked up.
    Regular Member mark_w's Avatar
    cheshire
    did the wheels actually lock up when driving? or do you mean that when you went to drive it the wheels were locked?
    this time of year the pads can stick to the discs if you had, for instance, washed it the previous day and the water had frozen the pads to the disc. or, if it's been parked for a week or 2 after being driven on a salty road, the pads could stick to the discs that way because of rust.
  2. brake problem
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 16th May 2011, 20:28
  3. new rear brake problem
    By davidjameswest in forum General Chat
    Last Post: 11th May 2009, 10:26
  4. Brake problem
    By leeroy in forum Suspension, Wheels & Brakes
    Last Post: 31st December 2007, 20:59
  5. Brake problem
    By masmit in forum Suspension, Wheels & Brakes
    Last Post: 27th October 2007, 18:29
