Results 1 to 10 of 13
Thread: Changing speakers
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    Default Changing speakers
    hi all
    just wondering if any one had suggestions for changin the existing speakers for some better ones? what make models would be best without having to fit an amp and bass box as need my boot space but want some decent sound?
    any suggestions appreciated.....cheers
    also any how too's?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    You could fit a small bass speaker in the right hand side cubby in the boot. You can buy Alpine units just for that task.
    Nov 2007
    Leeds
    any links or model numbers? maybe a how to if i not pushing my luck?
    Surrey
    There is somehow 2's in the how 2 section.
    Surrey
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by arkhan78 View Post
    Alpine Would be wise to get some measurements as i'm not sure if this is the same model as i've seen fitted before.
    Something I started.
    Nov 2007
    Leeds
    looks like a nice job ...anyone ever done this and finsihed it with pics...very tempted to do it myself....not done a build for years though
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    ^^ would like to see this finished article
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I was just experimenting. Its the sub from an old amped vibe enclosure I dismantled. The amp is in the other cubby. I had a independent controller up front to adjust the bass.
    What I really needed was a Free Air Sub as that set up is just the baffle and no enclosure.
    To do it properly you need to build the box then find out its volume (as in cubic cm's not sound) then just buy a sub to match. Subs usually state what size enclosure they need. If not any good Car Audio place will be able to sort you out. I sound defend the hole area with roofing felt stuff, same as dynomat but sh!t loads cheaper.
    You can always make the enclosure out of glass fibre but thats a different skill.
    There's enough room behind there if you have a later Vec, earlier ones had a nice little basket behind the door to hold your stuff and its molder to the boot card but as usual later vecs got it dropped so loads of room. Luckily though my farther had a later company vec so I just swapped his for mine.
    The little screw heads make good fixing points on the boot floor so no need to drill. HTH
    Nov 2007
    Leeds
    this seems like a wicked idea i use to build fiber glass boxes for the local chavs 10 year ago....i think ill stick with just switching the existing speakers with some that have crisper sound and good built in bass....
    any recommendations and what size do i need?
  1. Changing Speakers
    By liam8282 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2015, 16:50
  2. Upgrading speakers without changing head unit
    By Shogun in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2011, 12:16
  3. Changing out standard speakers?
    By cont1204 in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2011, 17:33
  4. Changing the Speakers in my Signum 07?
    By Billybb in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2009, 16:28
  5. Any options for changing speakers in back?
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2008, 21:10
