Results 1 to 10 of 20
Thread: xbox360 connections
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default xbox360 connections
    just wondered what the best way is to have the xbox wired up to the tv..
    I've got a 42" samsung plasma and its currently wired up with the component hd cable that came with the xbox...
    is this outputting hi def?.. or would a HDMI cable be better?
    Winteringham
    if your xbox has HDMI use the HDMI it will be better
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    use a hdmi cable for best results m8
    Regular Member SWIPER's Avatar
    liverpool
    Hey,i just bought my son a 19 in flatscreen for his xbox. Then found out its only a monitor for a pc (that he is using it for now). The question is, is there any adapters out there for the xbox to fit this screen!!...aggggggg!
    Winteringham
    yes you can buy a VGA cable
    http://cgi.ebay.co.uk/NEW-COMPONENT-...1%7C240%3A1318
    can get cheaper but would recommend genuine Xbox 360 cables
    liverpool
    Phew!....thanx very much matey.
    Thats quite cheap too.
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by carteg View Post
    When i run both my 360's through the same TV (42" plasma) you can tell which one is connected via HDMI, the picture is so much better than the one connected via components.. defo go the HDMI route..
    Winteringham
    no problem happy to help
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by SWIPER View Post
    You might need a Y splitter for the sound, i've got a 19" dell monitor that we sometimes connect one of the 360's through, and the VGA leads come with phono audio connectors, our 19" monitor has a dell sound bar fitted which has the normal PC sound connector 3.5mm jack plug, so you may need the Y splitter that converts the 2 phono leads to a 3.5mmjack plug and also coupler to connect the 2 x 3.5mm jack plugs together so you get the sound from the 360..
    We got our Y splitter and coupler from maplins
    liverpool
    Can i do that??
    My screen only has a single connection...
  1. What connections...?
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2008, 13:33
  2. BSR PPC connections?
    By FiscusFish in forum Diesel Engine related
    Last Post: 30th April 2008, 15:33
  3. ISO connections
    By R13hard in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2008, 00:21
  4. PS3 Connections?
    By Stevel in forum Games Room
    Last Post: 9th December 2007, 22:57
