my gear box is gone would this one fit my car
04 1.8 energy vectra c
http://cgi.ebay.co.uk/VAUHALL-VECTRA...1%7C240%3A1318
thanks ben
thanks ben
if you get the F-- number off yours and ask him what that one is
The F number will help, but a F23 from a Zaffy, Astra, Vec B wont bolt straight onto mine as there all cable operated, all Vec C's are hydraulic. I'm sure there will be a conversion kit out there as the main box will all be identical with maybe slightly different final ratio's.
Bit of homework, all 1.8's through the modern VX range are fitted with variants of the F17. Variants being the F17, F17+ and each then split into CR and WR (Close ratio and Wide ratio) Sorry mate I know that doesn't give you the ultimate answer you were after but you have a bit more info to help you along.
tar mate for that info
What is your engine code Z18??? With that I should be able to tell you your exact box.
