Results 1 to 10 of 13
Thread: Judder at 2000rpm?
    Regular Member jamesr's Avatar
    Lancashire
    Default Judder at 2000rpm?
    My car has started to judder slightly when under load.
    At approx 2000rpm to 2500rpm then dissapears
    Any ideas?
    wigan
    my 1.9 cdti 150 diesel does this
    Regular Member mace's Avatar
    Jan 2008
    Wiltshire
    I'm very far from an expert but try searching for threads on "DMF" and see if you recognise any other symptoms
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by phildjohnson View Post
    My CDTi had this problem several months ago, it was recognised as the injector loom on cylinder 3 which was replaced with no further problem HTH
    UK
    Thumbs down
    Mines started doing this as well for about a week now, always just slighty over the 2000RPM. It looks like my third injector has had some work done already, there is a thicker wire going to it, although it doesnt look very
    professional done.
    UK
    Mines still juddering although a little more so over the weekend. This morning while I was bombing down the dual-carriageway I got the spanner come up, bit of a shock as i lost loads of power. I quick pull over and restart of the engine cleared it but not sure if its the injector or not.
    I had a look at the 3rd injector over the weekend and it looks like someone has got another injector plug (doesnt look like any of the other 3) with slighty thicker wires and shrunk wrapped it to the existing wires, the wires from the injector is only about 1.5 inches before it merges to the existing wires. Im not sure if this is an offical fix. Should the thicker wiring go further into the loom?
    Full Member
    Bristol
    Default 3.0 cdti
    My 3.0 CDTI vectra has the same problem between 1500 and 2000 rpm.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by sb1uk View Post
    My V6 judders under full throttle from 2500 to 3500 rpm...
    UK
    Oh, and I always get the spanner when i hit 4000RPM. I'll get the code out to see what it is.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by cookie View Post
    Press the brake pedal and hold it and then press the throttle and hold it too. Put the ignition on and the emision light should show you a code by flashing.
  1. Replies: 0
    Last Post: 8th August 2011, 16:39
  2. Judder at 2000rpm (tried a few how 2's) Help !
    By Tim in forum Engine & Drivetrain
    Last Post: 15th April 2011, 09:00
  3. 2000rpm?
    By lencuff in forum Engine & Drivetrain
    Last Post: 22nd November 2010, 23:56
  4. car wouldn't rev over 2000rpm
    By Gt-Coupe in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2010, 16:04
  5. what should the power be like under 2000rpm
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 16:30
