Thread: Autospark Help!!!
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    Eek Polo on Fire !! Autospark Help!!!
    Out on the pi55 the last night so left the siggy at a mates house.
    Driving to collect it in the other halfs wee vw polo,next thing smelt burning plastic looked down and smoke started belching from under the steering wheel were the fuse box is!!
    I pulled over ignition of popped the bonnet no engine smoke at all.
    started the car and drove it the small distance back to my house and no smoke and everything electrical working
    Anybody any ideas its a 1997 polo 1.4 auto with only 44k on the clock just passed mot.
    The other half wants me to buy here a beetle now
    Oct 2007
    Back in Belfast!!!!
    anybody any ideas on this?
    Jun 2007
    Black Country
    any water managed to get in to the fuse box? ex wifes Scirrocco had this problem, seems common on VW, water would short across the terminals and throw out loads of smelly black black smoke
    Oct 2007
    Back in Belfast!!!!
    yea that sounds the same guyver what was ur solution do u remember.going to have a good look in the morning but can't see any damage and everything works?
    Jun 2007
    Black Country
    removed all fuses, dried them all, dried the fuse box as best as i could, and if i remember right, the water was coming through a leaky seal around the window, i put plenty of mastic around the trim
    Oct 2007
    Back in Belfast!!!!
    cheers for the response guyver will give that a go in the morning!
    Oct 2007
    Back in Belfast!!!!
    done as guyver said today had the fuse box out,not much sign of water tho also no sign at all of any burnt wires?just a bit dusty.put everything back together and drove about today no problem,with everything working?
    Regular Member mushy2007's Avatar
    Liverpool
    Did you have a curry or a kebab after your night out?
    You may have had involentary rear end discharge!!!! lol
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    check for leaves at the front where the heater is. Make sure it is clear.
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    make sure your insurance is ok and dont leave any valubles in the car and be prepared to run if the worst happens
