Thread: RE-External temp sender fault
    wales
    Default RE-External temp sender fault
    Fitted new sensor, display still reading high, Anyone Know how to recalibrate sensor?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Take it you mean the one in the bumper? All I can think of is resetting the hole lot by disconnecting the battery for 30 mins. I've disconnected mine several times while taking the bumper off and its always spot on when refitted. Might be worth checking the connections.
    wales
    yes its the one on the bumper, will try discon bat tomorrow, cheers mate
    Vehicle : SRi
    Mileage : 137000
    Depending on your HU you might need to put a code in the sterio to get it going again and also reset the electric windows. To reset the windows, hold down until you hear a beep and then up until a beep on all windows. HTH
    wales
    have code for sterio and know how to reset windows, Last motor Omega 2.5 V6 REFECTION. Cheers
    Vehicle : SRi
    Mileage : 137000
  1. Un-plugging coolant temp sender plug
    By chaz in forum Engine & Drivetrain
    Last Post: 1st March 2011, 22:12
  2. Where is the coolant temp sensor/sender on a 3.2 Petrol?
    By marcdale in forum Engine & Drivetrain
    Last Post: 1st June 2009, 11:08
  3. Wanted Wiring diagram for External Temp sender
    By flint666 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th April 2009, 22:56
  4. Help with Temp Sender Sensor
    By kryton01 in forum Engine & Drivetrain
    Last Post: 4th December 2008, 11:12
