Stopped off at service station tonight and went to turn lights off and then ignition (I think it was in that order!) and got a warning come up on the screen and on the dash saying 'Check Left Low Beam' , so then I switched on the lights again and no bulbs were out, however a few miles before I pulled up I was adjusting the the headlamp height range switch, so now I'm not sure if it's something to do with that (checked that also and appears to be working ok) or was it just referring to one of the bulbs? anyone else had this happen and found all bulbs etc are ok?
Cheers Pete
