Thread: Exhaust emission light
    leicester
    Question Exhaust emission light
    just recently the EXHAUST EMISSION LIGHT has started coming on, orange engine light on the dashboard, at first it was occasionally but now the light stays on.
    Usually I have no problems driving with this light on but sometimes the car judders when accelerating as is generally sluggish .
    Can anyone advise as how to cure this myself or is it a visit to my garage?
    Maybe O2 sensor in the exhaust. Or MAF sensor..........
    leicester
    Smile
    Thanks for the quick reply.
    Someone else has suggested the Lambda sensor, is it easy to locate / change?
    Regular Member mattolly86's Avatar
    oxfordshire
    yea pretty easy well was a 1.9cdti 120 think it was a 23mm spanner.
    make sure the car is cold (or it could really hurt)
    pull off pipe from intercooler to throttle body
    pull off coolant pipe and hold up with zip tie to stop leaking to much coolant
    the lambda sensor (o2 sensor) is bolted into the down pipe you now have access to unclip the electrical connect 6 pin i think as its heated. now loosen with spanner unscrew it and change however this may not be the problem i had simular problems with an intercooler hole, however if it turns out to be maf i have a spare one
    leicester
    confused
    is there anyway I can check that it is the lambda sensor, I have read about a "paperclip test" ?
    oxfordshire
    nope not on your car has to be tech 2 at a garage
    Quote Originally Posted by bluefozzy View Post
    Not if its a vectra c. The paperclip test could be done on the b's but not the c's.
    leicester
    Thumbs up
    Cheers, I will have a look and let you know how I get on.
  1. Emission Light On After Having New Exhaust
    By Andie-100 in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2011, 06:08
  2. exhaust emission light on
    By meganmm in forum Engine & Drivetrain
    Last Post: 28th March 2011, 13:03
  3. EML and Exhaust Emission light.
    By DHobbs in forum Engine & Drivetrain
    Last Post: 4th January 2011, 22:40
  4. exhaust emission light
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2009, 21:13
  5. exhaust emission light ?
    By STAV in forum Engine & Drivetrain
    Last Post: 25th October 2007, 14:16
vectra c emission light still on after new exhaust
