Thread: help needed
    Regular Member davidlewis24's Avatar
    bridgend / wales
    Default help needed
    hi boys looking for a bit of help if possible i have just fitted a pair of white led side light bulbs on the vectra 2.2 im now getting a bulb warning light on the dash and brake light warning on the sceen ive checked over the car and all lights are working fine ???? any ideas on how to remove the warning light and on screen message any help gratefull thanks
    Blantyre
    Vectra's dont like the LED's.... your lucky to get them working, mine wouldnt even light up... i dont know how to clear the bulb warning light
    Regular Member Damian's Avatar
    Market Drayton
    Pretty sure it is to do with the fact that LED's are a no no, as the Vectra has a bulb warning system which involves sending a voltage to all the bulbs at regular intervals to make sure they are working, if the voltage is not returned the car thinks the bulb has blown. An LED I believe is insufficient in it's power requirements to satisfy the bulb warning system.
    Not sure why the brake warning light is on, could just be a loose connection into the cluster
    bridgend / wales
    cool thanks for your quick response what would be the best sidelight bulbs to buy ?
    Regular Member Robbie69's Avatar
    Just take them out mate, you won't get round the problem. Plenty of threads on here on the subject.
    Blantyre
    I bought a set of Philips 501 BlueVision sidelights car bulbs blue vision from ebay, there pretty good
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
