Thread: Speedo & Rev counter not working on vauxhall vectra cdx 1999 modelv
    Abingdon
    confused Speedo & Rev counter not working on vauxhall vectra cdx 1999 modelv
    Hi all,
    I am new to this forum and have a problem with my Vectra 1999 2.0L CDX.
    My rev counter and speedo have stoped working recently.
    When I turn on the ignition key, the speedo vibrates.
    When driving both the speedo and rev dont work.
    I have removed the clock twice now to check the back conector and got it to work for about a minute, and goes dead again.
    The problem must be somewhere else.
    Please help
    Fredweb.
    Birmingham
    From previous experience, I know that the connections for the speedo and rev are in the passenger foot well - under the left kick panel.
    But if it flickers slightly, I doubt the connection would have come away with messing?
    Try it!
    Bye bye Vec B
    - Hello Siggy!
    Abingdon
    Hi and thanks,
    I have tryed looking under the pax side, all looks fine and well connected.
    Any other ideas please.
    Birmingham
    Fuse?
    Bye bye Vec B
    - Hello Siggy!
    Abingdon
    Fuses are all fine.
    What I dont get is how comes when the clock is removed and put back in place the speedo and rev counter works fine for a very short period
    Birmingham
    Could just be a lose connection somewher, get another set off fleebay on the cheap and try them in, process of elimination.
    Bye bye Vec B
    - Hello Siggy!
    Abingdon
    Hi, vaux-man-g
    Managed to purchase a second hand clock cluster on ebay for £20.00 and it works.
    Thanks for all the help
    Speak soon.
    Fred
    Birmingham
    Hey Fred,
    Quality mate. Glad you got it working!
    Cheap fix in the end. Glad to be of help (if I did in anyway)!
    G.
    Bye bye Vec B
    - Hello Siggy!
    Cheshire
    I know this is an old thread but i have the same problem with my Vectra.
    Fred (if your still about) when your clocks started playing up did you get PG09 displayed where the mileage should be? and did you notice any sort of missfire?
    I have the same symptoms but am waiting for some clocks i bought of e-bay to arrive, in the mean time i've checked all the grounds, pluh at the back of the clocks, Alt charging level (which was 14.8v so i put a new regulator in the alt and not sits at 14.2 at 3000rpm)
    Does this sound simalar?
  1. rev counter, speedo problem
    By victorM in forum Electrical & ICE (including SatNav)
    Last Post: 21st August 2011, 21:41
  2. Speedo and rev counter stopped working ??
    By Knuckle in forum Vectra C / Signum Troubleshooting
    Last Post: 11th June 2011, 16:59
  3. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  4. Speedo / Rev counter etc
    By AngryDog in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 01:30
  5. speedo and rev counter eratic
    By johnrolfe in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2008, 19:22
