Results 1 to 10 of 25
Thread: Urgent help needed - PS3
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Currently- VW Golf
    Trim : Mk7 R 300bhp
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Default Urgent help needed - PS3
    My lads new PS3 keeps swithing itself off when its just been switched on !
    Any ideas why ?
    Need to know asap just to get some peace and quiet !!!
    Blantyre
    Is he turning it on by pressing the PS button on the middle of the controller ?
    Press it once,
    If you turn it on by the PS3 its self, sometimes causes a double tap and turns it self off, its a sensitive switch
    6 Post(s)
    Trim : Mk7 R 300bhp
    Year : 1 A.D
    Mileage : Rising
    Quote Originally Posted by spennny View Post
    Press it once,
    Will try now.
    6 Post(s)
    Trim : Mk7 R 300bhp
    Year : 1 A.D
    Mileage : Rising
    Still turning itself off.
    Switched off at the mains and switched back on. Switched on at back of PS3 then pressed the PS button on the controller, still switches off !
    Regular Member KieronGSI's Avatar
    Apr 2008
    Aylesbury
    Does the fan work? Is it overheating? It will turn off if it is.
    Blantyre
    Is the power lead inserted fully mate ? 3 pin one at the back of PS3
    6 Post(s)
    Trim : Mk7 R 300bhp
    Year : 1 A.D
    Mileage : Rising
    Quote Originally Posted by KieronGSI View Post
    Its not hot only just switched it on.
    All are plugged in as far as they will go.
    Blantyre
    Did he do an update , close an update down , or did it fail to update, you may have to format the PS3 and start again ?
    Is it straight out of the box ??
    Regular Member mattolly86's Avatar
    oxfordshire
    the ps3 must have a motion sensor they have to be still to be turned off and does it double beep when it turns off?
    Blantyre
    Quote Originally Posted by mattolly86 View Post
    whit ??
  1. urgent help needed.
    By adierolfe in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 09:53
  2. URGENT help needed
    By vectraedition100 in forum Engine & Drivetrain
    Last Post: 27th February 2012, 20:21
  3. urgent help needed?
    By webber446 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 14:30
  4. urgent help needed >>>>>>
    By justin79 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2011, 20:02
