Results 1 to 10 of 17
Thread: Battery problems
    N. Ireland
    Default Battery problems
    hi all. a few weeks ago i was having battery problems and ended up buying a new one. this morning i went out to the car and the new one is dead again. i`m just wondering does anyone have exp in this happening to themselves? is it a duff battery? alternator? electrical fault in car? i have a multi meter and am going to go out and do a few tests. so if someone tell me what voltage`s i should be getting that would be great. ..finally one last thing where/ how can i test my alternator?
    Mileage : 000
    Put all your electrics on "ie" lights heated screen everthing. The reading from the meter you put on the battery should still show a charge. Switch of everything and the battery should show about 14 volts.
    N. Ireland
    Quote Originally Posted by ed taylor View Post
    HI, tested it there.
    battery on its own: 14v
    with engine runninig: 15v
    engine running with everything on 13v
    any ideas?
    N. Ireland
    think i need an amp meter to see if it is using any current with everything off. my meter doesnt have one of these :-(
    Regular Member mattolly86's Avatar
    oxfordshire
    well your readings seem fine should be 14.7 v while running though me thinks you prob got a short some where. sorry
    Mileage : 000
    Have you checked the earth wire and all the conections. You might have one that is loose. Or you might have a short somewhere ( though I doubt that is the problem). Might sound daft but are all the interior lights going out when the door is shut. Also fold the rear seat down when the boot is closed to see if the boot light is stuck on.
    N. Ireland
    tbh i checked this after reading other posts, my boot light is defo off, glove box is 90% of (think if i bent the door any more trying to see it would break, the switch is working tho) and the interior light is never on ( i have it set to not come on with open doors etc)
    Mileage : 000
    I wonder if a faulty alternator could send the battery to "ground" and in effect short it out??. Even if the readings from the battery indicate the alternator is charging, I wonder if it could discharge the battery when the engine is switched off.
    N. Ireland
    Quote Originally Posted by mattolly86 View Post
    it might be 14.7 my meter doesnt do decimals so i think it has maybe rounded it up to 15. is 13v with everything on sound right? dont think its the alternator (well hopefully) as last night etc it seemed fine but next morning it died. also lately a couple of times i have thought my lights have been of when infact they have been on ...im just thinking now that maybe they havent been getting enough power
    N. Ireland
    could it be a duff battery? its only new. its a lucas one
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. Battery Problems
    By danny1992 in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2011, 16:51
  4. good old battery problems again
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 16:18
  5. alarm, swirl flaps, battery, problems
    By dth150 in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2009, 20:30
