Results 1 to 10 of 15
Thread: Window Misting up!
    Regular Member Avenged's Avatar
    Liverpool
    Default Window Misting up!
    Last night... had teh AC to get REALLY warm, as it was baltic.
    Got on the motor way and then all of a sudden.. then windows. all of them, misted up realy fast.
    not good when ure on the motor way... in the dark!
    i cleared it like, by putting on the window blowers.. via the button on the control panel.
    Anyhoot.. why did this happen?
    Does my pollen filter need replaceing? or was it just a freak of nature!??
    Your thoughts on this please!?
    Mike
    Did you turn the AC off and then they misted up?
    Liverpool
    No.. it was still on when it happend.
    it used to do that on my old megane tho when i used to turn it off! lol
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    as above was this after turning ac off?, change the pollen filter would be the best bet,first check there are no damp areas in the footwells on seat and in the boot, by any chance have u used fabreze or similar in the car recently as they will make the car damp and then cause misting.
    Liverpool
    Nope.
    Aint used any fabric cleaner on the seats.. and the ac was on while tis happend!
    Weird, unless the outside temp dropped below 2-4 degrees and the AC switched off - as it only works above a set outside temp.
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    I find i have this problem when the air recirculation is on
    Liverpool
    Quote Originally Posted by Sean-2.2Direct View Post
    hence why i thought it may be the pollen filter!??
    Have a look at the pollen filter, it may indeed be a little blocked
    Apr 2008
    Liverpool
    How much are pollenfilters as mine has not been replaced yet i dont think now on 30k
  1. Misting Up
    By Homer in forum Bodywork & Interior
    Last Post: 16th November 2012, 08:16
  2. n/s fog sill misting
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2010, 20:13
  3. Rear hatch window misting up
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2009, 14:10
  4. Headlights misting up in the wet...?
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2007, 20:35
  5. Misting Up
    By cdtisri in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2005, 22:18
