any hints on how to remove the plastic trim/skuttle panel under the wiper arms at the bottom of the windscreen? b4 some thing gets broken
From what I remember , take the wipers off , then there is a rubber lip seal on the engine side which pulls off .
Then very carefully pop the scuttle out of the windscreen on one side and work your way across , it sits in a plastic channel on the bottom of the glass.
_same info as above but clean plastic channel out and smear a little grease in so you dont have to use as much force to reassemble if your not sure you knw where i am..... a 2 minute drive is better than a cracked screen
http://www.vectra-c.com/forum/showth...754#post759754
See, the search function does have its uses!![]()
