Thread: Swirl Valve Again!!
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Default Swirl Valve Again!!
    I suspect a swirl valve problem on my veccy again (fourth time) problem now is of course the bl**dy warranty has run out three weeks ago. I was waiting on some thing like this to happen the minute the warranty ran out
    Is there anything I can do to sort this problem out my self (no not over a cliff) as it will cost me a packet to get this done I suspect.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    if your car has FVSH then contact your dealer,there may be a possibility that vauxhall may pay something towards the bill,you will need to be persisant though,and you may have to phone vauxhall,your mileage must be either just over or idealy under 60k miles
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Trim : Elite with sports pack
    Engine : CDTi 150
    Mileage : 103000
    Does the 2.2 have Swirl Valves
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by Thunder View Post
    nope,the 2.0/2.2 diesels do have a throttle block that does get clogged up,it is worth stripping off the inlet manifold every once in a while and give it a clean including the egr valve
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 103000
    cheers solorider
    preston
    Ive seen a thread somewhere on here where you can repair the swirl valves for a quid using some plumbing rubber type washers. I would certainly ask the dealer to contribute to repair as although the warranty has ran out, goods whatever they are should last a reasonable length of time after the warranty period and 3 weeks is not a reasonable time. Dealers need good press in the current climate!
    Dec 2005
    West Lothian
    Yes they do, on the 2.2 Direct petrol engine. As I have had them looked at three times already!!
  1. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  2. Egr valve, swirl valve problems etc..
  3. oil and swirl valve
    By POAH in forum Engine & Drivetrain
    Last Post: 28th September 2010, 21:29
  4. Swirl Valve Rod ....
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 19:15
  5. Swirl Valve Q??
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 11:30
