Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Vectra C 1.8 Club Help Please
    West Midlands
    Default Vectra C 1.8 Club Help Please
    My car has started to do this after changing the head gasket and the mechanic is confused himself on what it is any help will be apreciated, link is below and thanks in advance guys.
    http://uk.youtube.com/watch?v=_tk4tljBBXE
    Is it the tappet oise or the bad idle your thinking of?
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    jeez..that does not sound good at all, sorry im no help but I hope you get it sorted soon m8
    West Midlands
    its not much tappety untill it gets warm and then shows the engine oil light off and on, but its more of the bad idle when you start the car even when its cold, any ideas? thanks
    West Midlands
    Thanks Morphun i hope so to mate, it started of with headgasket now i got this trouble on my head
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Did you remove the exhaust mainifold and, if so, did you use a new manifold gasket? The tapping noise is reminiscent of a Vec-B i know with a cracked manifold. If you've got an air leak, caused by the gasket joint on the manifold, you'll get the tappety noise as gases escape through the leaky area and cause the engine to run rough.
    As I don't know what you have to remove on a head gasket change, is there any chance the timing chain was removed and the bottom end is now out of sync with the top end/valves?
    I ain't no mechanic but may be worth asking yours the question and having a looksee.
    Also does the throttle body need a clean?
    West Midlands
    wel the mechanics told me to leave it untill monday after he has a good look at it, but not to worried about the tappety noise gtr1000 im more worried about the bad idle as its not ment to do this and it didnt when i gave the car in and it starts to mis when you drive, i hope its not a big problem but i will keep the manifold gasket in mind and let the mechanic no. thanks
    West Midlands
    cleaned the throttle body big sig also changed the spark plugs today with new platinum ones but still no luck
    West Midlands
    oh by the way he did check the timing, and its a belt and he said thats all properly done, and its all in the right place so hes pretty lost on this to.
  1. Hello to vectra club
    By cookie01 in forum Introduce yourself.
    Last Post: 1st April 2011, 14:14
  2. Newbie to the Vectra Club
    By funkies1 in forum Introduce yourself.
    Last Post: 25th April 2009, 22:00
