hello guys uhhh i have a slight issue with my blowers asthey only work on no4 not 1,2,3 just full blow on 4. any ideas wat 2 check???cheers fella's
Have a search for the resistor pack - search on here. Normally caused by a blocked drain by the pollen filter that lets water into the fan. hth
Common problem. Theres a drainhole under the bonnet which gets blocked. Water builds up under the scuttle panel, runs in through the pollen filter and lands on the motor and resistor. Link below explains it all for you.
http://www.vectra-c.com/forum/showth...maplins&page=1
As said by big sig resistor pack its a big problem on fiats done loads easy to change once youve found it usually near fan motor
cheers mate im going to investigate![]()
