Thread: Cdti 150 no power
    Oct 2006
    ayrshire
    rolleyes Cdti 150 no power
    Hope some of you guys can help,
    Just had the car recovered home
    Was driving to do a bit of shopping today, the car was fine, it a 05 150 vectra by the way,
    Suddenly when going to accelarate normaly the car had no power,
    stopped the car and attempted to pull away, car will rev but very very slowly and once it gets to 3000rpm it goes like stink again
    So in brief car goes like normal but only over 3000 rpm
    No lights on and is a bit lumpy when about 2000 rpm
    can you help
    Moderator paulhb's Avatar
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It is either the EGR valve which works below the 2000 rpm turbo cut in point or it is the number 3 fuel injector wiring loom, the later sounds scarey but is a loot cheaper. Check this thread out.
    http://www.vectra-c.com/forum/showth...njector+wiring
    Mine had the same problem but the EGR was fine but you can clean it yourself and save a shedload of cash check it out here
    http://www.vectra-c.com/forum/showth...t=egr+cleaning
    Oct 2006
    ayrshire
    thanks mate will have a look
    Oct 2006
    ayrshire
    Cleaned out the egr valve and cleaned all connectors on the fuel injection, also made sure and cleaned the swirl connections onto of the head, cleared the fault light and away it went, so good so far!!!!!
    thanks for your help
  1. No power from 1.9 cdti 150
    By garetmcc79 in forum Engine & Drivetrain
    Last Post: 1st April 2012, 08:04
  2. 1.9 cdti 150 no power
    By baz_cdti_sri_150 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 15:00
  3. little power 150 cdti
    By smokydiesel in forum Engine & Drivetrain
    Last Post: 26th May 2010, 19:13
  4. 150 cdti with no power
    By pauly in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 00:23
  5. 150 Cdti down on power??
    By shrekster in forum Engine & Drivetrain
    Last Post: 7th December 2008, 00:19
