Thread: 2.2 DTi benefits
    Kent
    Default 2.2 DTi benefits
    What is the benefit of having this engine as I can't see any at the moment, if you want performance dont go for it and economy wise my computer is showing 38mpg.
    Is this just my computer playing up or does the 2.2 dti deliver poor economy? (I dont drive it enough to find out)
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    Quote Originally Posted by fattony View Post
    The fuel economy in my old 2.2 dti was very good, regulary averaging 45-50 mpg. I suppose it depends on what types of journeys you are doing.
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    mine used to be about 47mpg but just recently dropped to 42 mpg but is slowly going back up at a rate of .2mpg a day. i had nearly 3 month of local driving now back on to an 80mile round trip a day
    Chelmsford
    tried resetting the computer?! should give you a true representation of economy after a day or so
    Nicking Ya Dinner.
    You should get 35 urban and about 43 on the motorway, up side is it's normally a good engine with a few known niggles, and it's a whole lot faster than a 2.0 DTi, has a chain drive.
    Common faults are
    1 - Turbo Hose Split or comes loose
    2 - Spill pipes erode causing bad starting
    3 - Crank pulley can fail
    4 - MAF can fail, gives gutless performance
    Other than that I can't think of anymore common fault's.
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    And cost....
    If you want a CDTi 150 then it means buying a newer car.
    I have a 2.2 DTi and i'm happy with consumption. I am getting 41mpg average and thats a mix of motoway and town.
    Performance is ok but buy a petrol turbo if you want real performance. Mine had all the spill pipes replaced and new injectors and glow plugs just before I bought it There is a receipt for £700 thankfully paid for by the previous owner so my car is running well.
    And I have had no problems at all since I bought it 4 months ago..... touching wood....
    Jon
    Kent
    Well I have a new MAF, got that under the warrenty, I reset the computer as it just stayed at 41.6 all the time, when the engine is cold it was 30.2mpg.
    I've just cleaned the boost pressure sensor still got the egr valve to do.
    Spill pipes hmmm it turns for maybe 4 seconds before starting, I wouldnt mind better they are expensive to replace and difficult to even check.
  1. Benefits and costs of a KN air filter?
    By Shogun in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 20:14
  2. Extra benefits from dog ownership
    By SignumPhil in forum The 'Off Topic' room
    Last Post: 29th September 2008, 12:08
  3. K & N Filter Benefits?
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2006, 00:32
  4. The Benefits of the EU!
    By MLC in forum General Chat
    Last Post: 27th May 2006, 14:23
  5. One of the benefits of fatherhood
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2006, 11:25
