Thread: Traffic master
    Regular Member johnboycdti's Avatar
    rotherham
    Default Traffic master
    Hi just wondered if it is possible to fit the traffic master from the vectra b model into the vectra c model?? and has anyone ever installed it??
    Regular Member pauls898's Avatar
    Malvern
    Yes it is, I fitted mine, if you have the standard ICE cdc2005 or cdr2006 then it will interface with no problem. When you change to an aftermarket headunit then it can get a bit more difficult but possible to do with the right leads
    rotherham
    cheers mate where abouts have you fitted the traffic master switch any pics ??
    Mileage : 000
    I would imagine you could use one of the "spare "blanking plugs and cut a hole in it for the traffic master. get a lsrge blob of"blue tac" and press it over the blank switch and pull it out, then you will have an idea if it will fit there. good luck
    rotherham
    cheers will give it a go..
  1. CD70 Traffic Master - Anything?
    By Aidi in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2011, 17:15
  2. CD30 MP3 & old Traffic Master???
    By Jay Kay 313 in forum Electrical & ICE (including SatNav)
    Last Post: 16th November 2009, 06:07
  3. Sat Nav Upgrade TMC Traffic Master
    By stevej in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2009, 18:52
  4. Vec B traffic master retro fit?
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2009, 21:36
  5. Traffic Master in to CDC40
    By willc01 in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2006, 23:52
