Thread: power steer4ing
    Regular Member Martybhoy's Avatar
    Motherwell
    Default power steer4ing
    as title!! when car starts in the morning, i getting a weird drooning whining noise and when i move the steering wheel, the pitch changes, thus i think its steering ive been told the steering is electric on my signum. so is there a list of possibles or has anyone else encountered this type of thing??
    Marty
    A bit of a whining noise from the steering is normal as it's electro-hydraulic. If it's really bad then it may need looked at. Might be worth just checking that the steering fluid level is up at the right level.
    Motherwell
    isnt it a sealed unit? the steering does get stiff momunterally though?????
    Marty
    The rack is a sealed unit but there is a reservoir of fluid that needs to be checked. Any drop in fluid can indicate a leak and low fluid can result in more obvious noise when turning the wheel at low speeds/stationery. The momentary stiffness can also be a symptom of low fluid - so I'd definitely have a check that it's not low.
    Motherwell
    ok, reaaaaaly stupid question, were is it and how do i top it up??
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Quote Originally Posted by Martybhoy View Post
    This is a Bi^%h to doo.
    I have been told that the Alternators also plays a part in the steering on vectra C's.
    Mite be bad advice but someone he will put that right
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
