Thread: can anyone help - problem with battery and warrenty
    Apr 2008
    Liverpool
    Default can anyone help - problem with battery and warrenty
    hi,
    my battery seems to be leaking and needs replacing, there was all blue crystal like substance on the battery don't really know what could have caused this.
    the Vec is a 1.8 sri on a 57 plate.
    took it into vauxhall and they are saying that the warranty is void as the garage I bought the car from was not a vauxhall dealership and therefore when they serviced the car after it was 11 months old that they invalidated the warranty?
    can anyone help please what could have voided the warranty? and are there any ways round this?
    thanks
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Hmm I did not think that would matter to be honest as you should still have a standard 3 year warranty. some one will know more.
    Were about in liverpool you from?
    Apr 2008
    Liverpool
    from childwall area you?
    yer I can understand if they had messed with the battery on the service but it was only checked so is still original battery and wires etc.
    cheers
    Apr 2008
    Liverpool
    Ahh your not that far away from me im from Speke.
    To be honest they probably have not even touched the battery just a defunked one .
    one of the other lads on here will have more understandings than I do on warranties
    Belfast
    Quote Originally Posted by A Falling Brick View Post
    Total rubbish. Tell them to wind their neck in and give you a new battery before you call trading standards.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What is the warranty on batteries? If it's 3 years / 60 K miles, then as ZS says, tell them you will call trading standards. Did the servicing garage use genuine VX parts to the schedule and are they VAT registered? If so, then EU block exemption would make it ILLEGAL for this dealer to refuse warranty.
    I don't know if the battery has the 3 year warranty, but I think it may have.
    Batteries SHOULD last more than it has.
    Is the battery actually defective? Have you had it tested? If you washed off the crystals with plenty of water, would they come back? Is there any physical damage to battery?
    Does the battery need toppping up? Or is it sealed? Does it actually work OK? Ie crank the engine easily?
    Apr 2008
    Liverpool
    yer battery working fine no battery light on don't know if it's chargin though cause don't know how to test this. there is no physical damage to the battery and i haven't tried wiping the blue stuff off cause didn't know what it was.
    the company i used are vat registered,
    from the service details the original garage sent me the checked all the usual and only replaced air filter and oil change by the looks of it.
    I don't know if they used vx parts but the parts they changed would not effect the battery anyway?
    I sent the details of what the garage gave me over to vx and they said that it does not state the milage or date these where carried out but the service book is stamped with date and milage and vx are refusing to accept this stamp???
    I don't know how else to prove anything to me think they want blood out of a stone if you ask me
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Just mention block exemption laws and see what happens.
    The blue is probably just copper sulphate, caused by low electrolyte in all probability. I would remove the cell caps and check if they need topping up.
    Oct 2007
    estonia
    in order to keep your cars warranty, the car must be serviced according to vx predescriptions: performe the needed service on time, use original parts, perform all nesseceray checking/adjusting operations during the scheduled service. Stamp from an independant workshop means nothing unless you have the invoice along with a checklist to back it up. The invoice must contain:
    VIN of the car or registration plate number
    date of repair
    mileage of the car on that day
    part numbers (vx numbers) that were replaced
    oil grade (5w30, 0w30 etc.) + oil brand. VX insists on using Longlife oil.
    a checklist of the works that were performed during the service.
    If you have the invoice and checklist then I dont think any dealer will refuse of your warranty request.
  1. [Problem]Battery dies way to often
    By kristinn in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2013, 21:27
  2. Alternator or Battery Problem?
    By bu_zz2020 in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2012, 20:03
  3. Battery problem
    By robhullfury in forum Diesel Engine related
    Last Post: 23rd March 2012, 02:53
  4. battery problem
    By jpdtm in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 09:51
  5. Not a battery problem?
    By Craigmill in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2008, 08:58
