Thread: noise when clutch is pressed???
    liverpool
    Default noise when clutch is pressed???
    I pressed the clutch, after dropping a mate off earlier this evening, when i noticed it made a strangle rumble sound. The door was open at the time and was the only reason I heard the noise. I can only describe it as similar to an engine straining slightly. Is this normal or does it sound like the start of a problem??? Any ideas?
    Cheers,
    Andy
    Maida Vale
    I think thats the classic sign of dual mass flywheel problems.
    liverpool
    Quote Originally Posted by Thomas1 View Post
    cheers but what is this?
    Maida Vale
    The flywheel for the engine. I'm not an expert by any means, but here are some threads:
    http://www.vectra-c.com/forum/showthread.php?t=63887
    http://www.vectra-c.com/forum/showthread.php?t=62670
    liverpool
    Nice one, I might take out that warranty over the net. If it saves me £500 it cant be bad.
    Thanks again,
    Andy
    Jun 2007
    Black Country
    could it be the thrust bearing?
    that was a common issue on cars years ago
    liverpool
    Quote Originally Posted by Guyver1 View Post
    I wouldnt hav a clue mate, I dont know what the thrust bearing is.
    Jun 2007
    Black Country
    thrust bearing was a large ball bearing that fitted at the end of the clutch, cost peanuts to replace when the clutch id being changed but a lot of dodgy garages didnt fit them, knowing you would be back 6 months later to get that changed too
    liverpool
    cheers, If/ when i get the clutch changed I'll make sure that is done too.
  1. Lauder diesel "clacking" after clutch pressed 2.0 DTI
    By slimo1 in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2011, 13:43
  2. noise on clutch
    By gasrac in forum Engine & Drivetrain
    Last Post: 24th May 2009, 18:39
  3. Rattle from clutch when pedal is pressed half way down.
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2008, 17:33
  4. Noise on clutch
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2008, 11:54
  5. DMF, Who's got the rattle when the clutch is lightly pressed ??
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2008, 03:24
