Thread: Auto Gear Box leaking
    Winteringham
    Default Auto Gear Box leaking
    Jacked the car up this morning to start changing the bushes and noticed loads of red oil all over the underside of the car, looked as if it was leaking from hoses coming from gear box. Very quickly put wheel back on and took car to Local Perry's dealers for them to look at.
    Got told have very large Transmission fluid leek not to drive car can leave with them until tomorrow when they could look at what is causing the leek and hopefully fix it in time for Christmas.
    Warranty expired on 2/12/2008 so am I going to get a big bill? do I need a new gear box, had no warning signs saying low pressure.
    Hertfordshire
    If it still drives ok, then it looks like you'll be lucky and have caught it in time.
    If it has been run dry or overheated, then internal damage is likely, but it doesn't sound like it got this far.
    It may be something as simple as a split pipe or leaky connection.
    Assuming this box is like others I know, the fluid is pumped from the box to the oil cooler under a fair amount of pressure, so even a tiny leak, will actually look quite bad, especially as it has been driven like this, the air passing under the car will have spread the oil everywhere making it look even worse.
    All you can do, or they can do, is clean it up and see where it is coming from.
    Winteringham
    thanks hopefully it is only small leak, yes the car was driving but as I drove it to garage it was hesitating when changing gear.
    Quote Originally Posted by carteg View Post
    Warranty expired on 2/12/2008...
    If it's not good news, as in needing new box/major work then I'd get onto Vx and see if they'll contribute). Given the climate I've heard that they're less ready to do this at the moment i.e. warranty expired means no help from them,but no harm in asking.
    If your mileage is low then more chance of them helping.
    Winteringham
    just done 39K miles, granted I've don 9K since 1st of August but still low mileage.
    Yep, that's a good 20k under the warranty limit, so definitely worth a shot talking to Vx given that you're only a three weeks out of warranty.
    Winteringham
    thanks I give it a try back down there tomorrow to pick up a courtesy car,
    Winteringham
    Finally Got my car back today after its been with the Dealers since 22nd December, it's had the inlet and out let pipes replaced for the Automatic transmission, new oil in the Gearbox and the oil cooler has been replaced, thankfully covered by third party warranty (warranty Direct)my lovely girlfriend had got me as a Christmas Prissie all I had to do was pay the £50 excess not the couple of hundred pound bill I was initially expecting.
    Well lets just say car changes gear a lot better than it was before, also put BSR remap back on and all I can say is WOW its a lot better than it was before.
    Look forward to nice drive up A19 to see everyone going to the meet and giving the car a proper run out.
    Regular Member poves's Avatar
    lancashire
    I bet warranty direct are impressed with you making a claim within a week ??
    To be honest I didn't think you could claim in the first month .
    Winteringham
    warranty started on 3rd december when vauxhall warranty ended theres started.
  1. Auto gear box reliability...
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 12:27
  2. auto gear box help anyone?
    By lukesignum in forum Engine & Drivetrain
    Last Post: 25th September 2010, 00:30
  3. Auto gear changes
    By Alansilverfox in forum Engine & Drivetrain
    Last Post: 13th June 2009, 19:56
  4. Auto gear box only 2nd & 5th pls help!!!
    By watkins1172 in forum Engine & Drivetrain
    Last Post: 12th January 2009, 19:48
  5. Auto upshift on 3rd gear
    By REDMGB in forum Engine & Drivetrain
    Last Post: 13th September 2008, 21:47
