Thread: cracked head
    Regular Member lilo1872's Avatar
    east-sussex
    confused cracked head
    hi guys,
    can anyone help me , ive got 2003 vectra c 2.2 sri with 50k on the clock with full service history , after just havin a small service at VX i found out ive got cracked head ! cant quite work out how that has happened considering my cars not high mileage and has fsh, must be a faulty part , do i have a leg to stand on by taking this up with VX and asking them to fix it ie pay for it ?.... or is just sods law and i have got to pay for new head myself.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You may have some redress through the sales of goods act, as any parts should last a reasonable amount of time, and you could reasonably expect the head to last longer than it has (and up to 6 years from original manufacture) BUT I really doubt you will actually get anywhere by it. May be worth a try, but I don't think it would be easy.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    My 2.2 head cracked, got it sorted under warranty. Mine went above the zorst ports, pumped oil all over zorst and bell housing. Its not cheap mate, second hand 2.2 heads are sort after due to the common snapped chain. What colour is your antifreeze? Your should only use Red in the Ally lumps, I've seen a couple of 2.2 heads ferked because guys have used blue. I believe the heads are inherently weaker because they are foam cast rather than sand cast but nothing for VX to pay out over.
    EDIT: Just looked at my dealer history print out, and if I had to pay it would have been £1386+vat for new head fitted, that was on a 26k lump.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    They are still sand cast, just with a foam 'head' insert that burns off when hot metal is poured (and the metal takes the shape of the foam insert). Foam casting isn't as good as other methods for dimensional accuracy or mechanical strength, BUT is quicker, easier and therefore cheaper
  1. Cracked head (Help/advice needed in chester)NW
    By srikev in forum Engine & Drivetrain
    Last Post: 4th October 2012, 15:01
  2. 2.2 head cracked
    Last Post: 10th December 2011, 20:54
  3. Cracked Snowflake
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2011, 11:16
  4. Cracked Snowflake!!
    By sol in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2009, 20:05
  5. Cracked Window
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2006, 22:00
