Results 1 to 3 of 3
Thread: Anti Role Bar Bushes How to fit.
    Garthorpe
    Default Anti Role Bar Bushes How to fit.
    I'm getting a grinding noise from the front of my car when I go over speed bumps so I have got a set of Anti role bar bushes from local motor factors today £4 each, only problem is I've been look for a how to, or a guide on replacing them but cant find it.
    I know there is one one here some where can some one please point me in the right direction so I can change mine tomorrow,
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    they are the same price at the dealers.
    once you have jacked the car up and removed the road wheel, you will see two torx bolts or 10mm headed bolts, you will need to remove the outer one completely and loosen the inner 1 till you can remove the bracket then just remove the old one and replace it with the new 1, and just replace everything as you took it apart
    are you sure it not the spring in the dish of the shock
    East Midlands
    Have a butchers at thie this bud ,should tell you all you need to know to change em.
    http://www.vectra-c.com/forum/showthread.php?t=31933
  1. Anti-Roll Bar Bushes
    By Monkgti in forum Suspension, Wheels & Brakes
    Last Post: 2nd February 2013, 20:56
  2. Anti roll bar bushes
    By Mark-R in forum Handling & Braking
    Last Post: 27th April 2012, 14:13
  3. Anti roll bar bushes
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 22:06
  4. anti roll bar bushes
    By mhvcbv in forum Suspension, Wheels & Brakes
    Last Post: 8th July 2008, 17:53
  5. i think i need anti roll bar bushes but!!
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 13:30
vectra c anti roll bar bushes fitting
fitting anti roll bar bushes vectra c
