Thread: HID kit install.. help
Hybrid View
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Default HID kit install.. help
    just went to install my HIDs and one side worked fine but the other side did not.. so i swapped the bulbs and 'POP'... its blowing the bulbs
    any ideas whats wrong.. i wired them both up the same way... its plug and go how hard can it be
    I found the problem but not the answer .... the bit where the warning cancellor connects to the Ballast can connect either way round... the clip can fit over the big OR the little notch on the ballast and the book does not say which way round it goes
    had any1 got an idea ?
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    did u use a power probe to check which was the live? there are 3 wires in the multi plug on the vectra loom which goes to the standard old h7 bulb.
    shropshire
    Quote Originally Posted by bobby-tupper View Post
    Will do that next time i have a go... gee im f daft.. havin 1 of them days
    Regular Member n_hudson's Avatar
    Mar 2008
    Northampton, UK
    I managed to get my wiring the wrong way round on one side a couple of times before they worked... Although, they never popped the bulbs. (The instructions were... a picture with no text...)
    Oct 2008
    Reading
    Default Ballast fittings
    From memory, the power plug on the ballast has a notch thingy on both sides, one is square, one has a slanted edge, the clip on the plug needs to go over the slanted one.
    Cheers
    Mark
    Regular Member Green Growler's Avatar
    Hertfordshire
    Quote Originally Posted by 137mph View Post
    Cheers
    Mark
    What he just said.
  1. new install in the vec
    By bensterzback in forum Quick Photo Album
    Last Post: 18th October 2010, 21:10
  2. What do I need for an install?
    By JamieD27 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2010, 07:05
  3. SAT-NAV what do i need to install??
    By Turbomanrony in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2010, 10:50
  4. My install!
    By smiley-sri in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2009, 22:44
  5. My little ICE install
    By bensterzback in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 20:08
