Found these for sale, but they list them for a Vectra 2002-2006.
What differance is there between the brake pipe connectors as mine is a My2006?
Due to be fitting my 314mm front brakes and would like a set of these fitted at the same time.
i would of thought they where the same baz and should fit whitout any problems![]()
Thinking on Glynn i believe that some have had to contact goodridge as the backs are a 12mm banjo fitting, and the kit comes with a 10mm banjo.
So how easy would it be to get them swapped by goodridge?
buy one of these kits, plus you will be able to get the fittings from your local motor factors![]()
I bought a set and the rear banjo's are 10mm diameter (selling in the the 'For Sale' section now).
I emailed Goodridge and they sent me some replacements with 12mm banjo's.
Dosn't matter Baz, i had my set off ebay for £25 + p&p (Glenboy iirc put me onto them) and all i said to the guy at Goodridge (who's name is Martin Taylor) was the rears didn't fit as the banjo's were too small.
He said a new set with the correct size fittings would be made and sent directly to me, they arrived about 5 days later at no cost.![]()
