Thread: grinding noise from offsisde strut area.
    Regular Member 22ultra's Avatar
    manchester
    confused grinding noise from offsisde strut area.
    i recently lowered myvec 40mm all round everything runnig fine until about a week ago.there seems to be a^^^^^^ and its driving me mad.all seems ok no pulling on the steering no braking problems just this ****** noise.any thoughts or anyone who has had a similar problem could you please help.thanks.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    did u get it 4 wheel aligned?
    Also have you checked the rear suspension arms?
    Doncaster
    The lowering could just be a coincidence, it sounds like the same problem I have just had with a ******ed wheel bearing. Problem I had was it all felt fine (spinning free and no play) untill it was sriped down and the drive shaft out then you could feel how rought it was.
    manchester
    Quote Originally Posted by daftarse View Post
    the lowering could just be a coincidence, it sounds like the same problem i have just had with a ******ed wheel bearing. Problem i had was it all felt fine (spinning free and no play) untill it was sriped down and the drive shaft out then you could feel how rought it was.
    def not bearings just had replaced,its sounds like the noise is around the top area of the strut(had a friend walk along side the car at slow speed and he recons it's withon that area).
    manchester
    Quote Originally Posted by merikiito View Post
    no do you think it would cure it.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Had a look at these on the fronts? Have you bent them? http://www.vectra-c.com/forum/showthread.php?t=47958
    Did you fit new shocks or just springs? If you did the struts, could be the cups/mounts on the bodywork where the struts come through in to the engine bay?
    Doncaster
    Have you checked for the tyre rubbing on the wheel arch? try jacking the car up from under the lower ball joint and spin the wheel
    manchester
    Thumbs up
    Quote Originally Posted by gtr1000 View Post
    shocks and springs,will check cups/mounts asap it does sound like it could well be this as it only seems to come from the off side.(all posters thankyou very much for all comments and help)cheers guys
  1. grinding noise turning right
    By jon ixi in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2015, 12:08
  2. LOUD grinding noise?
    By UncleMelon in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2012, 11:21
  3. grinding rubbing noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 09:49
  4. knocking / grinding noise
    By Graeme in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2011, 23:51
  5. Grinding Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 10th October 2006, 07:52
