Results 1 to 10 of 20
Thread: auxillary belt on 1.8?
    haworth
    Default auxillary belt on 1.8?
    i`ve just been checking the oil/water etc & noticed that the aux: belt is cracking and some split lines on it. i bought a new one but some help on how to slacken/retention the belt would be much appretiated, i`ve looked on How To but nothing on for the 1.8, the motors done 142k so the timing belt is probably due for a change too, it was last changed at 75k by previous owner. i`l do the aux belt myself but the cam belt will have to go to the local garage methinks. cheers keith
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is't it a spring loaded tensioner? Ie you simply lever the tensioner to slacken the belt, remove and replace and let go slowly?
    From memory, there is a square hole in the tensioner arm to insert a ratchet square drive and lever the arm
    haworth
    thanks, i`ll have a look when the damn rain stops.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    On the 2002/5 Cs 1.8 just fit a spanner over the nut on the idler pully, small one to the rear and move anti-clockwise to release belt, remove belt, replace with new one ensuring that the belt is fitted correctly around ALL the pullies.
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by carpet View Post
    Timing belt should be at 40-60k too
    May 2008
    Tyneside
    On the 1.8 when you release the tensioner there are two holes which align. Place a suitably sized drill in these holes which keeps the tension off and enables you to route the new belt, then ease the tension off the drill with the spanner and remove the drill. Sometimes pays to make a little drawing or photo of the belt route as its not always obvious when fitting the new belt. HTH
    Regular Member s0501291's Avatar
    Warrington
    can you fit a new belt without removing lots of parts? just through the bonnet. you dont have to remove the front OS wheel and arch liner?
    cheers
    Pete
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    From memory, nothing has the be removed, just the belt by releasing the tension as above.
    Jul 2006
    TENTERDEN KENT
    Nothing to remove, all that is required is one spanner and a new belt, dead easy job which is a nice change on cars nowadays.
  1. New auxillary belt and tensioner.
    By erni3wi5e in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2012, 18:51
  2. Auxillary Drive Belt..DTI 2.0
    By macdad in forum Engine & Drivetrain
    Last Post: 7th October 2010, 22:33
  3. Auxillary Belt..
    By nikroc in forum Engine & Drivetrain
    Last Post: 23rd February 2010, 23:42
  4. Auxillary Drive Belt
    By sdemps in forum Engine & Drivetrain
    Last Post: 7th February 2009, 13:57
  5. Auxillary drive belt..
    Last Post: 29th October 2008, 00:22
