Thread: can i make alarm chirp
    hampshire
    Default can i make alarm chirp
    have a 2.2 sri 2003. it has a factory fitted alarm and the lights flash when it is armed but can i make it chirp??
    It doesn't bleep when you set it matey. Just flash the indicators.
    Welcome to the site Scottie,
    Very interesting question as I wanted to make mine do it as well, ever since I was watching silent witness on telly and his vec did it !!! Thought nice sound dept but I wish mine could beep ..
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    You can get get an aftermarket speaker type thing put on that will do this, I had this put on my cossie when I had it. A good alarm supplier should be able to fit it.
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Alarm's probably controlled on Can Bus as I know aftermarket alarms we fit on Vec C wire in to Can Bus.
    I guess you could get a 12v beeper/sounder & wire it to an indicator bulb via a 5 pin relay connected to ignition so it doesn't beep all the time whilst you're normally indicating.
    hampshire
    think i will look into the aftermarket speaker. will phone around and let you know what happens
  1. CDTI Aux Belt Chirp - When cold or first start only
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 16th December 2012, 23:20
  2. Alternator chirp
    By tbclose1992 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 21:14
  3. Metallic Chirp\Squeak going over speed humps
    By joules2.0t in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2012, 21:23
  4. Noise when starting 3.2 (like a chirp!?)
    By effone in forum Engine & Drivetrain
    Last Post: 21st November 2008, 15:34
  5. Idle chirp
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2006, 22:02
