Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: 2.2 DTi. At 50 MPH spanner warning light comes on and car goes into limp mode
    Bristol
    Default 2.2 DTi. At 50 MPH spanner warning light comes on and car goes into limp mode
    Hi.
    I have a 2003 Vectra 2.2 DTi Automatic. At 50 mph (exactly) the spanner warning light appears on the dash and the power drops off (I think this is the car going into limp home mode).
    If I turn off the ignition and restart the car, the light is not on and the car drives fine - until I hit 50 mph again.
    Any thoughts on what the problem could be? I know people mention EGR and other things, but wouldn't that throw the warning light on straight away, and not wait till 50 mph?? Any ideas would be welcome. I'm reluctant to get VX to do a diagnostic but may have to.
    thanks
    Bristol
    Actually, the car has a real loss of power right from when pulling away until it hits 50 mph, and then the limp mode kicks in. Hope it's not the swirl valves!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    OK mate firstly check all your hoses connecting your turbo to to the manifold and intercooler (the two large one,s in front of your engine ) secondly check your vacuum hose and connectors for splits. next take out your boost valve and clean it with carb cleaner spray. remove egr valve and de-coke it .
    All of these can cause the problem you describe, if you go as far as removeing egr valve and boost sensor also remove manifold sensor is fitted to this will give you an improvement in performance.
    and still loving it
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    bob, when you say remove do you mean remove and clean or just remove?
    Engine : 2.0DTi
    Mileage : 73350
    Sorry about that should of been remove and clean
    and still loving it
    Feb 2006
    Guttedsville
    All spot on advice, but all I'll add is be very gentle with the boost sensor, it's a delicate bit of kit. A liberal spray with the cleaner and agitate it with a soft, small brush.
    Bristol
    Thanks guys. All sounds like good advice (and hopefully not too expensive!). It'll give me something to do on Boxing Day!! I've checked and a replacement EGR is almost £200, so I'll definitely try cleaning it first.
    saggy, good luck getting egr out, mines stuck fast had 2 attempts at removing it and failed each time
    Engine : 2.0DTi
    Mileage : 73350
    Craig your supposed to remove the retaining bolts first.
    and still loving it
    lol, i did, well two of them.#
    tried giving it a twist and pull, it just wont budge. tried with warm engine and cold engine
  1. 3.0 V6 CDTI AUTO - Limp mode, car/spanner warning light
    By Bigv in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd June 2011, 17:51
  2. faulty thermostat/limp mode/spanner light
    By collyb in forum Engine & Drivetrain
    Last Post: 19th April 2011, 20:20
  3. Spanner Light but no Limp Mode
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 13:07
  4. limp home mode but no spanner light??
    By mick 1986 in forum Engine & Drivetrain
    Last Post: 5th April 2009, 12:22
  5. spanner light on 2.2 dti and goes in to limp mode
    By thelad in forum Engine & Drivetrain
    Last Post: 14th March 2008, 21:48
vectra c 2.2 dti can air filter cause a spanner light on
could the thermostat put car in limp mode dti
vectra c 2.2 dti spanner light
