Thread: Help needed - C0131 ABS Pressure Circuit
    Hungary
    Default Help needed - C0131 ABS Pressure Circuit
    Hi
    The car started to display ESP failure it's been TECH'd and the failure code is C0131 ABS Pressure Circuit - "The measured value is out of range" (this is my traanslations as the TECH wasn't set to English).
    I searched the web and found some "clues" like:
    a, ABS unit needs replacement (2000 €)
    b, wrongly adjusted brake light switch
    It's worth to mention that the rear brake pads are close to zero (will be replaced in a couple of days).
    Do you have any idea what can cause this error?
    I hope it's only because of the brake pads or the brake light switch....
    Any help is appreciated.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I wonder if the ABS system has any air where it should not have. Have you disconnected any brake hydraulic pipes recently?
    Hungary
    Pipes were never disconnected and the brake fluid level is normal.
    AFAIK the ABS in Vec C & Signum should release the air from the brake system, does it?
    Sofia
    Hi,
    Same problem here. The ESP log an error and stop to function until restart the car. I notice the error appears when I’m pressing the breaks easily or unevenness of the road ( lot’s in my country ).
    Do you manage to find what can cause this problem?
    Hungary
    Quote Originally Posted by valvebg View Post
    Hi,
    Hi
    actually I coud solve it on my car
    'Flushed' the brake system and now it's OK.
    The brake fluid was quite dirty, like metal and dust would have been dissolved in it.
    You can check easily to take a look into the brake fluid tank/reservoir and if it's not clean, then worth a try.
    You can buy 2 x 0.5 liter brake fluid (grade DOT4 or above, check the car manual beforehand) and ask a friend to help you either pumping the brake or release the fluid. If you are not familiar with the process you can take it to a service...
    I hope it helps.
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. Replies: 7
    Last Post: 22nd August 2011, 14:41
  3. Z22YH high pressure fuel pump needed urgently!
    By simp_2.2sri in forum Engine & Drivetrain
    Last Post: 27th April 2011, 22:18
  4. P1191 - fuel rail pressure sensor circuit low input
    By L11Marc in forum Engine & Drivetrain
    Last Post: 17th March 2009, 17:12
  5. Tyre pressure settings needed asap.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2008, 21:07
