Thread: Help please: seems the buyer of my CDC40 does not know how to fit it!!!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Help please: seems the buyer of my CDC40 does not know how to fit it!!!
    http://www.vectra-c.com/forum/showthread.php?t=64491
    As for the post above I sold my HU to a member on here.
    They are now asking for a refund because the HU show SAFE when fitted.
    Doh I did explain in my ad that the HU would need to be Tech2'd into the new car but he insists that this is not the case and it should work start away.
    So VX spent a small fortune on putting security on the HU's only to allow you swap in and out of a car and they work!
    Come someone please back me up and tell the buyer it needs to be Tech2'd into his car as he wants a refund.
    This is the first time I have ever had a problem with selling something on the forum.
    thanks for your help guys
    Full Member spennny's Avatar
    Blantyre
    If its Tech'd 2 out, which i see, then it would have to be tech'2d in i would presume ??
    Can i ask whats the difference between CD30, and this one ? Is the sound better or what
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Twin tuner so you do not lose your fm stations, better sound and a 6 CD player. some of the newer units also play MP3's. You can also add twin audio and DAB
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Below is an ebay add for a CDC 40 direct from Blaupunkt in Germany.
    £306 plus postage and without a GUID from what I can see. So the £150 the member paid is a bargin.
    http://cgi.ebay.co.uk/Blaupunkt-Radi...1%7C240%3A1318
    If you read through the ad then you will see the following information:
    Vauxhall Radio CDC 40 Opera - Charcoal metallic
    - Original part number: 13.113.151
    - This device is delivered without code which is not needed. The Vauxhall Service installs the radio without code in your vehicle using a diagnostics tester.
    - Without operating instructions. If desired, you can obtain it at any time from your appointed vehicle dealer.
    Maybe Blaupunkt don't know what they are doing either
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think the buyer does not have the car security pass for the car as stated in my ad.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I have called their local dealer, Evans Halshaw and they say it will cost £45 as they have a set charge to do it. Not bad for 3 mins work. Now if only the buyer will take notice!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    when tech2´ed out of donor car. it Needs to be tech2´ed in to the new car.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by kenp View Post
    Thanks for the reply confirming the tech2
    Sunny Dartmoor
    I'd take merikiito's word for it m8,he is a very genuine bloke and can be trusted,just take it to your local dealer and ask them yourself,he is not a con man,he is a very trusted member on this forum,hope that helps Lee.
    Ashington, Northumberland
    I will also confirm that it is the case that they need tech 2'ing out and tech 2'ing in if transferring to another vaehicle. Now that the answer has been confirmed a few times, and that was the point of the tread, I am now closing it, just to save anybody any embarrassment should this thread go daft
  1. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
  2. Best HPI check for a buyer?
    By ronnie63 in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2012, 20:30
  3. GB Car Buyer question
    By AFA82 in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2012, 17:41
  4. Hi All! Advice for a possible buyer?
    By Marticus in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 07:38
  5. Buyer in need of advice please
    By p-a in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2011, 14:54
