Results 1 to 10 of 17
Thread: Aircon and fuel.
    Regular Member Atomic's Avatar
    Southampton
    Default Aircon and fuel.
    Does having the aircon on have a huge impact on the fuel the car uses?
    I am under the impassion that it does so i do not use it very often, only to keep the seals lubricated.
    Regular Member scottyd's Avatar
    paisley
    i did usde mine all summer and dont realy notice a difference just slightly adjust your driving style and it wont impact at all
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 25000
    Quote Originally Posted by Atomic View Post
    In a word, no. IMO
    Some people are horrified at the prospect of using the 5% extra fuel that air-conditioning reputedly uses. It has been said driving with the window open uses more fuel and that at motorway speeds less fuel is 'wasted'. Aircon is there to be used, whenever you need to.
    Driving enthusiastically burns more fuel than aircon ever could.
    Regular Member mark_w's Avatar
    cheshire
    i once worked out that my vectra B did about 2mpg less if i used aircon all the time, not a lot considering the difference to comfort it makes on hot summer days. just used occasionally in winter to clear the windows, i would say the difference to mpg is negligable.
    Mileage : 000
    I don,t think leaving the air con on affects the fuel consumption on my motor. I leave the air con on all the time.
    Maida Vale
    Leaving a window open only increases fuel consumption at speed....if you doing 30 in town, it won't have an impact.
    A couple of mpg on mine, but thats about it.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Aircon WILL affect fuel consumption, it has to as it is taking power from the engine, so you need to produce a little more to get the same power at the wheels - simple physics.
    However, this reduction will only mean about 5% increased fuel consumption. So the simple answer is are you prepared to pay 5% more for fuel and keep AC on?
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    i allways have mine on and i don't seem to notice any difference so i'm not bothered. also i'm 99% sure that cas larger than 1.6 don't use more than 2% fuel with aircon on due to the engine being so large the extra load is minute,in my fiesta 1.6 i had before the 2.2direct vec when u put the aircon on the cars idle would seem to strugle now has this ever happened to anyone with a car bigger than a 1.6 prob not, case solved, thank u detective clouso.
    Southampton
    I have only had the car a month so I will have to wait until it gets a bit hotter to see. But it sounds like people don’t notice a lot of difference so that’s a good thing!!!
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  4. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
  5. aircon V fuel
    By dezzie in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2006, 16:49
