Results 1 to 10 of 11
Thread: smoking from the exhaust
    stoke on trent
    Default smoking from the exhaust
    i have got a vectra sri 2.0t 2004 and it is smokeing very heaverly i have been told the turbo as gone dose any body know if the tubo can be repaired or have i got to get a new one
    Nicking Ya Dinner.
    It could be a number of things tbh, you at best could have valve stem oil seal trouble, or ring wear, the turbo is also a suspect, and a simple thing to check is that you've not overfilled it with oil.
    Regular Member mooney's Avatar
    North west
    Trim : VXR
    Engine : 2.8 v6 turbo
    Year : 06
    what colour is the smoke?
    Tyneside
    Are you sure it's not just because of the cold weather mate. Mine is very smokey, but has only started since it got cold and looking at other cars it's very similar, just down to the condensation. Blue smoke is the sign of a wearing turbo.
    Nicking Ya Dinner.
    Quote Originally Posted by mark1319 View Post
    I was just going to add that, don't confuse steam with smoke, it's been cold and the exhaust heat billows out of the back.
    stoke on trent
    The smoke is blue and you can smell fuel plus it is using a lot of oil
    Tyneside
    If the smoke is blue then that's a tell tale sign of turbo failure. If you have a search through Duncan's thread he sent his to turbo technics for a service after the actuator failed. Not sure what would have to be done if the turbos capoot, but I'm sure it'll be cheaper than getting a new one.
    Nicking Ya Dinner.
    Hmmm, sounds ringy, you need a compression check on it before you fork for a turbo.
    Forum Moderator FIL 4822's Avatar
    Central England
    Vehicle : Vectra VXR, VW Tiguan R-line Tech, Vivaro.
    Trim : Nav
    Engine : Various
    Year : 1 A.D
    Mileage : Rising
    I've had turbo failure on 2 cars in the past and both times its white smoke, very thick white smoke in fact due to the very high temperatures associated with a turbo. Check the intercooler aswell (for oil).
    Blue smoke is the sign of a lower temperatures i.e valve stem seals.
    stoke on trent
    Thanks for the advise
  1. Smoking
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 17th January 2012, 11:24
  2. smoking exhaust
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2010, 17:36
  3. smoking from the exhaust
    By gary hough in forum Engine & Drivetrain
    Last Post: 29th December 2008, 09:14
  4. smoking from the exhaust
    By gary hough in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2008, 10:05
  5. No Smoking
    By VauxVeteran in forum General Chat
    Last Post: 8th July 2007, 12:01
