Results 1 to 10 of 21
Thread: Help!!
    Barra
    Default Help!!
    Hi boy and girl
    I need your help,
    I have problem with the display screen have been pushed by an accident, it may look like need a new replacement so I have been looking at ebay and see if I can buy a replacement so finally I have email from a guy say that he can give me the replacement
    so I was worry about how can I fix it? how difficult will that be? doe it need the battery disconnect or alarm code before use??
    plus do anyone have trouble with the boots that doe not open by the keyfob or side door button should automatic open? cos I have to open by the key?
    please please help me! it vauxhall vectra 2.2i 16v 2003 and its amazing car!!
    Regular Member poves's Avatar
    lancashire
    Can anyone else decipher this ?
    Barra
    ffs,
    How difficult can it be to replace the broken computer display screen? doe it need a security code? doe it need the battery disconnect before to start replace the computer display screen??
    [Ex]Admin Duncan's Avatar
    Don't think it needs the batttery disconnected, but probably no harm in doing so.
    What problem are you having, what have you been trying to do?
    Have you removed the trim around the screen? i..e. the bit with the vents on it. Once that is off then the screen simply unscrews out.
    Barra
    The display screen got damage and its all blurred, you wont see the date, time, temp,
    I was thinking of buying another part to replace it, I know what you mean about the bit with the vent, I was worry what if I did break it? how can I take it off then unscrews out?
    and then what?
    cheer
    Sorry Gary you've lost me a bit. What have you tried so far and what exactly is it you need to know? Are you asking how does the screen come out? I touched on that in my last post but for a full How 2 I'm pretty sure there is a thread in the How 2 section.
    Barra
    I've done nothing so far, I wish I could take the picture and shown you and you will see what I mean,
    all I want is how could I take the vent frame off and then unscrew the display screen out and replace it the new display screen and then put the vent back,
    if I do that then do I need the security code in case anything happen?
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    What HU do you have?
    To get the screen out unclip the strip that runs across above the gloveboxand below the vents, with this removed you'll see the screws for the vent assembly.
    Barra
    not sure think it CD2005?
    I'll let you know tom what have I done so far ok
    cheer for your help
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Pull the Silver trip strip up from passenger door, then along to the stereo. There are 4 T25 (or T 20's) that need to come out. The Vent/Screen just lifts out from the bottom. The Screen then needs to be unplugged. There are then 4 screws that hold the screen. £ min job tops. Regarding the screen, I think, (could someone confirm this?) the old half can-bus is just plug and play. You don't have to disconnect the battery. HTH
    PS, mine is the 2005 and i've had the screen out loads of times no problem.
