Thread: 2.2 cutting out, annoying!!
    Regular Member 1smokinace's Avatar
    notts
    Eek 2.2 cutting out, annoying!!
    hi guys, im a newbie and i need some help, my 2.2 veccy c has started to stall under braking, it has been dipping revs quite low recently during braking but now its cutting out?? it starts back up fine and drives with no probs, until i come to the next junction that is!! any help would be greatly appreciated. also do these have sensors fitted to the brake pads? thanks mark.
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    Hi mate, try taking the throttle body off first and giving it a good clean, not a hard job, just disconnect the air pipe into it, then unclip the plug, 4 bolts to undo and off she pops. Just wipe it clean as they can get a bit gunked up, I know mine used to dip in revs, never cut out though, but was fine after I did this!
    Check the air filter is clean too!!
    As for the brake sensors, only one of the wheels has one, and I'm damned if I can remember which one, but I'm sure someone knows, I think it is the nearside wheel!
    Surrey
    When was it last serviced?
    I thought nearside wheel too.
    Regular Member Bloicy 3.2 V6 GSI's Avatar
    Aberdeen
    Welcome Mark,
    I had a similar problem with my Vectra B and found out it was the Air Mass Sensor although i did get a warning light which the dealers read and diagnosed the problem. Do you have any intermittant lights coming on the dash? i would get it checked out anyway as it maybe something totally different unless anyone else has had similar problems with their Vec C and could confirm or advise differently.
    May 2007
    Quote Originally Posted by Bloicy 3.2 V6 GSI View Post
    If you find out it is this I have a spare for sale somewhere, let me know! I bought one thinking that was what was wrong with mine, (different fault), turned out to be the lambda sensor in the end!
    notts
    criky you guys are quik! will give these ideas a go at the weekend and will let you know the outcome, as for the brakes, there is a sensor on the nearside but is it connected to one of the pads or is it fitted to the calliper? thanks again, mark.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Sits into one of the pads, special cutout for it
    May 2007
    Quote Originally Posted by merikiito View Post
    Is that a clever pun to match his problem?? LOL!
    notts
    the missus has come from work saying the car is now ok. no cutting out although revs still dip low?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Vid View Post
    Now would I do that!
  1. how annoying
    By daddyjay in forum General Chat
    Last Post: 8th August 2011, 01:15
  2. Annoying dog
    By Graeme in forum General Chat
    Last Post: 30th April 2011, 21:00
  3. Really, really annoying....
    By joejdx in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 19:52
  4. How annoying
    By shan in forum The 'Off Topic' room
    Last Post: 10th August 2008, 17:00
  5. How to be annoying
    By Leviathan in forum Comedy & Humour
    Last Post: 28th July 2008, 13:18
