Results 1 to 10 of 15
Thread: is this my heated water jet plug?
    Regular Member Craig1985's Avatar
    harwich essex
    Default is this my heated water jet plug?
    is this my heated water jet plug? Its by the pollen filter on a facelift?
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    can't see a plug there...all I can see is a cable clip.
    harwich essex
    heres it circled
    @home
    Engine : 1.9 CDTi
    that looks like a cable tie to me. I think the plug would be further up the cable if it's there.
    @home
    Engine : 1.9 CDTi
    some pics of where it is... http://www.vectra-c.com/forum/showpo...2&postcount=32
    should be next to the pollen filter.
    Full Member spennny's Avatar
    Blantyre
    Craig, there all along the bottom of that area, its deceiving, as thats what i thought it was at first
    harwich essex
    na mine not on there. mine comes straight out of the bady work? Guess i might not have it then
    @home
    Engine : 1.9 CDTi
    Not all vec's have the plug, but the upgrade can still be done, just means a bit of wiring.. Pretty sure there are threads that detail how to do this somewhere.
    Full Member Big Sig's Avatar
    Its on the right hand side of the filter, clost to the top, if you have it
    Maida Vale
    On the subject of heated washer jets - when is the heater active? All the time the engine is running? Only when the rear windscreen heater is on?
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Replies: 42
    Last Post: 1st April 2012, 16:03
  3. lime water widget and plug
    By luke.oldham in forum General Chat
    Last Post: 27th March 2011, 09:29
  4. blue plug display into a grey plug vehicle
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 23:09
  5. heated water jets
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2007, 10:50
