Results 1 to 10 of 20
Thread: Saloon boot water ingress
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Default Saloon boot water ingress
    Ive heard of quite common water leaks on the hatch Vectras is under the roof channels, some sealent or other dries out and lets water in, and it runs down the C pillars into the back edges of ther boot...and have seen the How2 to get the roof lining out on a hatch, but how do you go about it in a dr saloon??
    My Dads '02 Elite 4dr has water ingress in the back corners of the boot, and its got that bad a couple of times that the speare wheel well was 2 inch deep!
    I'm pretty sure its not coming from the back lights and the boot seal is in good condtion and intact, so i'd reckon on it being the roof gutters or the ariel seal, both of which i'm going to need the headlining down to look at, so my question is, how do i get it down?....also, how do the roof gutters unclip, as i dont want to beak the clips ad Vauxhall will only sell a case!!
    Thanks in advance
    PS, I did search for saloon water leak and headlining etc but nothing came up.
    preston
    My hatch had similar problems and turned out to be leaking in from around the side vent which is hidden under the rear bumper. Theres one on each side. If you take off the rear bumper you can clearly see them. I siliconed mine in and cured the problem.
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Cheers, its one to look at certainly....although the water in my dads is deffinately coming from above and dripping down into the boot area.
    Jan 2006
    Skynet HQ EMEC#5
    Seems strange to have the water in the saloon boot
    It could be a bad seal around the rear lights.
    If it was the aerial base, surely the headlining would be wet?
    Have a look here, this is how I explained about removing the headlining in the saloon:
    (this was for the rear interior light, but it should help)
    http://www.vectra-c.com/forum/showpo...1&postcount=25
    HTH
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by Ian T View Post
    HTH
    Cheers Ian
    I'm pretty sure it isnt the rear lights, as it is appearing around the area of the boot cubbys, so suggests that its running down the inside of the C pillars same way as the Hatch water leaks do.
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    How do the roof gutters clip off too?
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    I managed to unclip the passenger side roof gutter, but couldnt see anywhere that water may get in, apart from something that was riveted from the inside, and was abit loose (I'll try and get a pic of it)....anyone any further ideas please?
    Its deffinately coming from above as i reached up from the passenger side boot cubby and there is some fealt or something and thats wet through.
    Ta
    Regular Member poves's Avatar
    lancashire
    If you need any advice on stripping the interior or outer trims etc feel free to pm me mate , just totally stripped mine yesterday .
    Regular Member linley85's Avatar
    sinfin, derby
    ive noticed i have the same problem on my saloon as far as i can see it seems to be coming from the boot lid itself not took the trim off properly to look yet gonna do it tomorrow so if i see anything i will post it up
    lancashire
    If any of you guys need the boot seal pm me as I have one for sale
  1. Potential water ingress area for saloon owners!
    By MadOnVaux! in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2010, 17:23
  2. Kitchen laminate worktop water ingress
    By Boy Lard in forum General Chat
    Last Post: 29th March 2010, 20:40
  3. Water ingress
    By ianmcv in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2010, 21:53
  4. Good news - my water ingress
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2007, 18:09
  5. Water ingress in the footwells
    By michal.lukasik in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2007, 18:25
vectra c roof gutter
