Results 1 to 10 of 14
Thread: Brakes seem to be sticking-SRI CDTI
    Birmingham
    Default Brakes seem to be sticking-SRI CDTI
    Guy's,
    Was using my dad's SRI CDTI 150 (FL) today and noticed something very odd.
    First of all the MPG had dropped to a 33.6 mpg, and then when I was driving, it just didnt seem to have the same kick about it as normal.
    Anyway, further driving and when I was slowing down, I just seemed to notice that the car came to a gradual halt ever so quickly.
    Then I investigated further and when approaching every junction, it didnt seem to roll to the end as it normally would (i.e. the traffic lights line). In fact when I let it coast in neutral it fell a good 25-30 metres short !!
    Anyway, my thoughts on it are that the brakes are sticking as I tried it on a quiet road and when I took off slowly, I could almost feel the car stop itself in the same way that the brakes would normally stop you (the same throw forward feeling-but obviously at slow speed)-I think you get what I mean.
    Then, when I eventually parked up I opened the door and I could smell something almost burning, it like the smell when a clutch is slipping. Anyway, I stuck my nose inside the back wheel and then the front wheel and smell seemed to be coming from the front!
    Has anyone had this happen to them before?
    What could be problems? Pad's, Calliper's, Disc's, Caliper Piston sticking?
    All ideas and suggestions welcome.
    Thanks in Advance!!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Feel the brakes, if they are toooooo hot they are sticking.
    Birmingham
    Well there was smell....if this is....whats the cure?
    Bye bye Vec B
    - Hello Siggy!
    May 2008
    Tyneside
    Sounds like a caliper may be siezed in which case replacement is required. On modern ABS systems it could be hydraulic pressure from a faulty ABS unit. If you spin the disc and it is binding, slowly open the bleed valve on the caliper to relieve the hydraulic pressure. If it still binds it is the caliper, but if it frees the disc then it is a problem with the hydraulic ABS system. A job for the experts. HTH
    Birmingham
    FACK....its only just out of warranty too! I knew summat would happen!!! Costly repair???
    Bye bye Vec B
    - Hello Siggy!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    mansfield notts
    hi, i had the same problem on my sri, 03, except it was the nsr, wheel steamed when it was raining, the trouble was the outer piston seal had split on the caliper making the piston rusty. had to fit a new caliper, not cheap, came to about £80, used an easy bleed to clear the air, very easy to do.
    si
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Some of the members who have upgraded to 314mm discs might have their old callipiers available for a small price. Might be worth putting up a request on "parts wanted"
    Birmingham
    I have managed to narow it down to the drivers side front wheel as after about a 7 mile drive...the wheel was piping hot!!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Quote Originally Posted by Vaux-Man-G View Post
    thats exactly where my problem is on my gsi im having the flexi hose changed today but i suspect its the caliper!!! ive also noticed a drop in mpg too
  1. Rear brakes sticking after cold weather
    By david106 in forum Suspension, Wheels & Brakes
    Last Post: 20th December 2012, 16:41
  2. Rear brakes sticking (vectra)
    By Steve 100 in forum Handling & Braking
    Last Post: 6th July 2012, 08:05
  3. rear brakes sticking
    By eminemme42 in forum Suspension, Wheels & Brakes
    Last Post: 13th March 2012, 21:20
  4. Brakes seem to be sticking-SRI CDTI
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2008, 19:22
  5. Sticking Brakes?
    By Big Sig in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2007, 10:43
