Results 1 to 10 of 11
Thread: Service indicator
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Default Service indicator
    If this displays 21000 does it mean that the service is due at 21000 miles or that the service is due in another 21000? The car has never been serviced and has currently done 17K so I assume it needs servicing in 4000 miles.
    [Ex]Admin Duncan's Avatar
    The 21000 is miles until next service. That's indicating that you're on ECOFlex, that it's just had a service and the counter has been reset (as 21000 is the max figure). I'm assuming this is a recently bought car? If so, I'd double check that they actually did the service (at the very least oil change and filter) and didn't just reset the ECOFlex counter.
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    I had this issue when mine came up for it's first service at 14 months. The odometer showed 20,000 but the service indicator said I could drive another 2,000 miles before a service is due. Beware! The warranty demands a service at 20,000 miles (petrol models) regardless of what the display says (which is only a guide and can be reset by naughty folk). Whatever people say, if you had a major failure at (say) 25,000 miles, they'd ask for your service book and check their records to see that the car had been serviced at the right interval and if they saw that you'd gone 2,000 miles over their recommendations, they'd be entitled to refuse the claim. Once the warranty has expired it doesn't matter, but personally I feel that 20,000 is more than enough for a sump full of oil anyway!!!
    Doug
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    would some kind person please tell me where the thread to reset the service light is.....mine is coming on when I start up saying 1000 til service..it was serviced 1500 ago when I bought it...rang the garage and they are as much help as dead dog !!! Thanks in anticipation...Bob.
    E Sussex & Kent
    Thanks will drop it off at 20K, wasn't convinced that even the 3.2 V6 could go 37K without a service.
    Jan 2006
    Durham...
    found it... done..
    Feb 2006
    Guttedsville
    Mine shows 31.000. Just been serviced. That'll ding dang do for me.
    Regular Member jonnye's Avatar
    Feb 2006
    Derby
    am i right in thinking the 3.0 CDti is every 30,000 miles?????
    Hemel Hempstead
    ECOFlex servicing on diesels is 30,000miles or two years. Whether you're happy to go that long without changing the oil is up to you, but I personally think it's a little too long.
    I suppose if your car uses a little oil, then as you are adding fresh throughout the period, that's not too bad....but if (like on mine) you don't need to add any between services, then the oil really is getting old and past-it by 30,000 miles.
    (Read 20,000miles for petrol engines)
    JMO,
    Doug
    20,000 Miles..
    call it a waste but the oil in our cars is dropped out every 6K miles or 3 months.. Using genuine VX parts you don't invalidate your warranty.. Even though Vx say you can go to these mileages i think that this is aimed mainly at fleet operators to minimise servicing during the lease period..
    Being a more mechanically sympathetic owner i could never leave it that long..
  1. service indicator
    By gizmo10119 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2010, 06:55
  2. Service indicator
    By stanian in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 23:17
  3. Service Indicator
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2007, 20:29
  4. Service indicator
    By CPHB in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2007, 14:41
  5. Service Indicator
    By Spelly in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2007, 23:04
