Results 1 to 10 of 11
Thread: Coolant change 2.0T?
    Tyneside
    Default Coolant change 2.0T?
    Is it possible to drop the coolant in the 2.0T? Got a leak and want to do a complete drain before I refill it.
    I'd remove the bottom rad hose, that would get rid of most of it
    Tyneside
    What side is that looking from the front of the car? Left or right?
    No idea, but it will be at the bottom of the rad
    Tyneside
    LOL I'll have a gander tomorrow Cheers mate
    Mark, there's an actual drain tap that you can use - saves you pulling hoses off. Basically it's in line, or therabouts, with the side of the rad and slightly set back - as in going away from the front of the car. From memory it's on the driver's side, but if you can't see it check the passenger side in case I'm wrong.
    I found it much easier to drain the coolant that way when I did my turbo than pulling a hose off.
    Tyneside
    Thanks D, hopefully get it done tomorrow
    Any idea what the capacity is?
    Not off the top of my head but it's in the manual if you've got one? If not then I'll have a gander for you. From memory somewhere around 4l is what I've got in my head.
    Tyneside
    Got the manual
    Tyneside
    7.7L is what I've got in the manual LOL
  1. Coolant change
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2013, 10:58
  2. coolant change
    By nick6515 in forum Engine & Drivetrain
    Last Post: 24th November 2012, 15:38
  3. Coolant change
    By Corey in forum Vectra C / Signum Troubleshooting
    Last Post: 14th October 2012, 21:26
  4. Coolant change
    By urbanfox in forum Engine & Drivetrain
    Last Post: 6th December 2010, 11:43
  5. Coolant Change
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 23:21
