Results 1 to 3 of 3
Thread: Any ideas on how to remove the panal with the heater controls is on?
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Any ideas on how to remove the panal with the heater controls is on?
    my heated rear window button/switch is sticking was wondering if anybody knows how to remove the panal to get to it?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The panel unclips,if you remove the cubby below then you can pull the heater panel out without levering against the surrounding dash, which is easy to mark.I think the switches are mounted to the pcb so be careful !
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Easiest way is to but a blunt plastic blade in the panel gap on the passenger side and prize it out. Its designed to come out this way as there are spring loaded clips on that side only. Had mine out last week to fit a Pro clip.
  1. Heater controls
    By Robbie5994 in forum Bodywork & Interior
    Last Post: 14th October 2010, 23:39
  2. Any ideas how to remove this?
    By n_hudson in forum Engine & Drivetrain
    Last Post: 27th June 2010, 22:43
  3. How to remove steering wheel controls
    By bnam in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2008, 14:29
